It is currently Mon Aug 04, 2025 5:37 am
 Post subject: bending herringbone purf
PostPosted: Fri Jan 30, 2009 12:42 pm
First name: Martin
Last Name: Edwards
So a guy wants me to build him something like this, (but with a round soundhole)
I've got a few strips of Stewmac's herringbone purfling and it seems stiff.
will it bend OK on a pipe?
advice PLEASE!!
PostPosted: Fri Jan 30, 2009 1:02 pm
Martin,
Make a form (half of your body outline) out of a piece of 3/4" plywood. Route a ledge in it the width of the purfling and twice as deep. Next, soak your purfling (both pieces) in water (I use my bathtub) for about 10 minutes. While you're waiting, take some binding tape and cut it into 3" pieces and place it every 1.5" around the perimeter of the mold (solid at the waist) from the bottom of the mold, leaving about 1/2 of the tape loose. When the soaking is done, push both pieces of purfling into the ledge at once, starting at the waist and working in both directions. Remember to point the arrows of the chevrons towards the neck end of the mold. Fold the tape over the purfling and secure to the top as you go. Be sure it's tight.
It's really very easy and the fit will be perfect as long as your mold is accurate. Good luck!
Jimmy Caldwell
PostPosted: Fri Jan 30, 2009 1:26 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
My 1st guitar was a Martin 000 cutaway kit and I added herringbone trim. I bent it with help from a more experienced builder with a hot pipe and it went well. We just dampened it with a little water spray and started bending. I have heard that too much heat or water can cause the glue holding it all together to let go.
Fred
Fred Tellier
PostPosted: Fri Jan 30, 2009 1:53 pm
Jimmy Caldwell wrote:
Martin,
Someone on this forum posted a method similar to this a while back that I have used several times with outstanding results. The only differences were to use a piece of PVC pipe filled with boiling water for softening the purfling and then use a piece of heavy cardboard marked with the pattern and the purfling held down with push pins. The purfling only needs about 20 to 30 seconds of the boiling water treatment to soften it. If you go too long, it will fall apart.
PostPosted: Fri Jan 30, 2009 2:03 pm
Here's one more way:
http://kennedyguitars.com/_Kennedy_Guit ... gbone.html
TJK
PostPosted: Fri Jan 30, 2009 2:25 pm
Martin, I'm a great believer in using the lowest form of technology that will get the job done (except in my professional life where I'd be lost without my Cray) I've use rope prfling a few times on soundholes with some success without ever using water etc to soften the purfling. The secret to me is not to be in too much hurry, so cut some channels in scrap larger than your rosette and cold bend the prfling into the channel, leave to take a set a few days and then bend it into a slightly smaller channel, until your ready for it to go into the finished size channel. I did try the wet method and steam etc but found more trouble with delamination than I wanted.
Here's a rope one (I tend not to like herringbone really) that I did early November which might one day end up on a guitar if I can get back to my workshop. This is a classical size 83mm soundhole. By the way I have found that the stuff from David Dyke is easier to bend than from SM.
PostPosted: Fri Jan 30, 2009 2:32 pm
Martin,
So your friend wants a Stefan Sobell guitar-bouzouki - good taste 8-)
PostPosted: Fri Jan 30, 2009 2:39 pm
I've used the Terry Kennedy method successfully. The hair dryer really helps and it remembers its new form every time.
PostPosted: Fri Jan 30, 2009 3:02 pm
Speaking of low tech secrets, it works out pretty well to just break it into the channel, cold and dry. A small ball peen hammer is helpful.
PostPosted: Fri Jan 30, 2009 4:18 pm
Yet another way is to separate it in half with an cloth iron and a razor blade. The halves will conform to pretty much anything.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Fri Jan 30, 2009 4:46 pm
I bend mine on the pipe. Just wet the inside surface and go slow. If it starts to de-laminate, I just put a clothes pin on the spot till it cools. But, I didn't have much problem with de-lamination.
PostPosted: Fri Jan 30, 2009 4:59 pm
Last Name: Cyr
City: Roseville
On my first acoustic I had LMII prebend my sides for me, but I puzzled for a while over how to bend the purflings (herringbone) and bindings (curly maple). I mentioned my dilemma to my wife, and she suggested a curling iron. So I went to Walmart and bought a $7 curling iron and it worked just fine. I clamped the handle of the iron in a vise, and used a damp towel to dampen the section of purfling l was working on (6 or 8 inches at a time). Now I have a Fox-style bending machine, and I've used that to bend the bindings and purflings too.
--Steve
---Steve
PostPosted: Fri Jan 30, 2009 5:21 pm
First name: Chuck
Last Name: Hutchison
City: Houston
That stuff melts like butter on a hot pipe. You won't have any problems. Just spritz it with water.
PostPosted: Sat Jan 31, 2009 10:16 am
First name: Josh
Last Name: French
City: Houston
For rosettes, I just wet herringbone a bit before putting it into the channel. Never broken one.
For purfling I use my side bender to prebend. Works well enough. But I've got to say that Jimmy Caldwell's method sound like a great idea and I am going to try that.
Instagram: @jfrenchluthier
PostPosted: Sat Jan 31, 2009 12:44 pm
I have used this method as well, and it works fine if you are careful.
Users browsing this forum: No registered users and 43 guests
